Hushmat?
Hush mat is a great product . Super easdy to install, but the damping results are not as good as Some others out there. Dynamat extreme is a better product in terms of performance, but Hushmat is bad *** in terms of install
ANT
Well I am getting some nasty rattles. So I need something to the extreme. I was there holding the hushmat and seemed very flimsy. I can see why it would be easy to install. But If it dosent damp well then have to go the dynomat why I guess. Thanks.
Cascade is fantastic stuff, a lot like dynamat extreme, but butyl based rather than asphalt so it doesn't have such an odor when the car is hot. Made a HUGE difference in my Si.
Dynamat extreme is butyl based too. Regular dynamat is the asphalt based. Secon skin is also butyl based
Second skin or raammat seems to be the choice around here. Raammat is less expensive and comes in a roll. The second sjin is more expensive and comes in sheets. I want to try ss personally
Ya, i hope to be able to get about 100sqft of second skin damplifier after i get paid next week.
Hushmat is absolutely fantastic install stuff. I like it much better than Dynamat extreme. The stuff is easy to cut and stick on... just need to use a simple wood roller or your hands to get the bubbles out. The stuff is about 52mm thick if you need a comparison.
bigbangtheory
bigbangtheory
Venus or Mars, just depends.
Spr0ket
