Hurricane Nuts?
Make the cutout bigger? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I have always wondered about using those as well though since I'm always taking my sub in and out of the box and having to drill new holes every other time. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I can do that, but the problem is that I can't rotate my sub (L7). I'm stuck with the same screw holes.
Yeah, then you're really SOL. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I say give em a shot. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Let me know how it goes and then maybe I'll start using them. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I actually used bolts on my 15" box because i took the sub in and out so much. It actually works fairly well as long as you don't try to overtighten them. I snapped one in half doing that. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
that only happened once though.
Maybe i'll try to get some pics.
if use them right they can be your friend //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
have you ever read the label on anything you screw? "do not over tighten"
so heres what you do.
line it up where you want them then make some markings. then predrill apply some glue or resin and hammer away //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif dont forget to test fit before gluing //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif then screw whatever needs screwing down until it feels tight enough no need to go Michael Jackson on screwing it tight
Would epoxy work? What kind of glue are you suggesting?
That would be a really good objective experiment.
I think I'm going to get a bunch of different glues, and test them with t-nuts somehow...
Lakota
Doesn't Know $hit
Lakota
Louisville, KY
Kil4Thril
