Huge fan of Hifonics till.....
kbwj24
Read a specs on some of the models and 35hz?! frequence response is from 35-250hz. Why would it have a subsonic filter on it down to 15hz though. I ran a hifoncs 1606d and it hit nicely novice at the time it was an awesome amp i then purchased a mtx ta81001 and well the lows really came out of my l7s. question though is can the hifonics make those lows or is it really limited. I no longer have the 2 amps to play with and i was wanting to hear from my hifonics fans.
This is what i read
Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
RMS Power Rating:
4 ohms: 550 watts x 1 chan.
2 ohms: 1100 watts x 1 chan.
1 ohm: 1600 watts x 1 chan.
MOSFET Power supply
Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
Wired remote bass level control included
Power and Protection LED indicators
Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Dampening factor: >250
Single-channel monoblock channel operation
1-Ohm stable
Phase shift: 0-180 degrees
Preamp RCA outputs
Input level control: 0.04V - 18V
Balanced line input for MX accessories and line drivers
Heavy duty aluminum alloy heatsink for extreme heat dissipation
RCA level inputs
Screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (15-35 Hz at 24 dB)
Frequency response: 35-250 Hz
Dimensions: 14-1/4"L x 9-1/2"W x 2-1/2"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Variable low-pass filter (35-250 Hz, 24 dB/octave) Subsonic Filter (15-35 Hz at 24 dB)
No, the frequency response would be the 15hz subsonic filter at the bottom, and the top of the sub frequency would be anywhere you want between 35hz and 250hz.
That "35hz to 250hz" is the low pass crossover, where the frequencies you set is the upper limit of your sub.
Yeah. I went from a hifonics 2608d to a saz2000d and I will never buy anything other then sundown.
Sorta same boat here...
I'm in the process of switching from the Hifonics 1500Ds to the Sundown 2000Ds... and a few 125.2s...
It will be a slow process as I can only afford to buy one every month or so as I don't want to charge them... Trying to get my **** C.C.s paid off...
Not really knockin the HiFoincs, I just think the Sundown looks to be a better amp...
You don't think Hifonics cheated by rating their amplifiers at the various power ratings from 35 to 250 Hz do you? They will probably play below 35 Hz, BUT, they will NEVER produce unclipped rated RMS power below 35 Hz no matter what the input voltage is. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Then again, they are budget amps and should be thought of as such when purchasing.
kbwj24
kbwj24
Rowlett, Tx
tRiGgEr
