HU Power Problem!!
  • 4
SOUNDSTREAM-LNP
Ok...i have HU that and all the gear for it...but when i tired to fit it into my truck all i found was a always on Power wwire....and there's no on and of power wire so when i trun my truck off the HU goes off and stays of but stores the time and when i turn it back on it goes on and it the same as i turned it off..but i can't get that...because i don't have that On/Off Wire...does any1 know...or have any idea's of where i can get this power from...i thought about just putting a wire into theA/C but i don't really want to have to press the A/C botton to turn on my HU...PLEASE heap
SOundstream-LNP
Originally posted by SOUNDSTREAM-LNP Ok...i have HU that and all the gear for it...but when i tired to fit it into my truck all i found was a always on Power wwire....and there's no on and of power wire so when i trun my truck off the HU goes off and stays of but stores the time and when i turn it back on it goes on and it the same as i turned it off..but i can't get that...because i don't have that On/Off Wire...does any1 know...or have any idea's of where i can get this power from...i thought about just putting a wire into theA/C but i don't really want to have to press the A/C botton to turn on my HU...PLEASE heap
SOundstream-LNP
ANYONE!! KNOW????
I'm with Spddracer, your post is very confusing, i'm not sure what youre asking for. The way you describe the problem in depth, it sounds like nothing is wrong, but when youre asking for a solution, it sounds like youre like youre looking for an igntion/switched power wire. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Take a look at your fuseblock it should have a few empty slots thatll say something like acc or bat. Take the wire from your h/u and run it to one the ones that say acc that should solve your problems. Thats what i had to do to mine.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
387
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
646
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
468
SOUNDSTREAM-LNP
SOUNDSTREAM-LNP
australia
80_Cutlass_mn
    May 24, 2024
