thegreatestpenn
lazy genius
I have a JVC kd-ar880 and recently I put the 4 speakers on the HU's internal amp for power instead of my usual outboard amp. I started noticing when I turned the music up past nominal levels that the HU would crackle and not sound right. Also when turned up too high the HU would shut off. At first I thought it was because the voltage was dropping below 10V, but I tested at my amps and the voltage wasn't dropping below 12.5 except for when I burped a tone (and the HU didn't cut off on the tone either). I have upgraded the HU ground so its not coming off the factory harness but a 12ga. wire straight to the chassis. I even upgraded the 12V wire with 12ga and a 15 amp fuse (same as on the deck) from the steering column. Yet I still have the crackling. I'm thinking 2 things may be the problem:
1) My ground wasn't good enough that I ran for the new ground.
2) One of my speakers is grounding out causing the whole internal amp to have issues.
if I can't figure out what's wrong I'll just have to add another outboard amp for the speakers again (not that its a bad thing), I just am confused as to why this would happen since I've never experienced a deck do this before.
