hu cuts off
patrick1202
ok so my hu is a kenwood and it just keeps cutting on and off randomly not even hitting a bump or anything.i can sit still and it will just cut off. what could it be i don' think it's wiring i have checked and redone my wiring three times and even had my friend check it. what could it be.also if i disconnect my batt for like 15 secs and reset my hu it stops for awhile.
Is the car running when it shuts off? Sometimes when my car's off the Alpine will shut off due as a feature. Means it's not getting enough power. Also, check for loose connections... power and ground
I had a similar problem with my old eXcelon. Long story short the harness plug in the back of the radio just never clipped in place tight enough, so I used a wooden shim to hold it in place tighter and problem solved. I just used one on the bottom to hold the plug up in place and so it couldn't wiggle around.
patrick1202
patrick1202
gallatin,TN
mlstrass
