how's everyone getting straight cuts??
table saw=money which i dont have. just gave Mike over at SS all of that stuff.......yah, my fence is clamped.....maybe i got a shitty eye, but even when the edge is flush and all it dont come out straight.
Money tight, then buy a better blade,(alot cheapr than a tablesaw) a tablesaw would do the trick, but if you had a nice blade(carbide tipped--at least 30 teeth), it would make a big difference.
I used a 10+ year old circ saw with the proper blade of course and a piece of aluminum channel as my guide, I dont think you could get a straighter cut.
Try practice and go slower or maybe a friend and I haven’t seen many perfectly square T-squares. I don't know a better blade will help if he is that bad. Because it would cut faster and easier so any side-to-side movement at all would be increased. All else fails cut it a little long like 1/16 and use a good wood file. Last time I bought a good carbide tip blade I think it was $60 a little pricy.
You can buy decent blades for 15 bucks or so. And if you come down to using a wood file, make **** sure your file is perpindicular to your wood, or your gonna end up in worse shape then you started.
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
Nikuk
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
