Hows a 4000w amp $160??
Lanzar amps are not overrated, just misrepresented. Do a little back ground check before you go and say they're overrated. Yes, it states on the main pages they are, but if you look at the manual (Found on Lanzar.com) they are not overrated.
This image was taken from http://lanzar.com/manuals/VIBE226-236-246-256-266-276-286-416-426-436.pdf
more than likely, user fault. i've had gone through about 3 installs which had the Vibe series, they're aiite, not the best of the decents but they dont break down that quick.
I've had 4 of the a/b's.
2 I bought new (230 and 430), used for a couple years - sold for decent money.
Only thing I could call a problem was some thermal shutdown when running the430 HARD at minimum impedance. Not even a problem really - just thermal protection doing its job.
Another 230 I put in my sisters boat - which she just traded in. About 4 yrs in a marine environment - never a problem.
Another 430 I bought used off ebay for $80. Used in my boat for a yr - one channel doesn't like to power up all the time. I can knock on the amp and it will turn on though.
snowshreder32
snowshreder32
OP,KS
n2audio
