How you configure your 4-ch amps and mono sub amp?
sj2000
Hi, I just finished installing 2 amps, Rockford fosgate P4004(4 ch) and Alpine MRP-M1000(sub amp), has anyone ever used the same amps, how you configure yours? I mean like in RF there are Gain Control, Bass EQ (0 - +18 DB), Crossover(High Pass, All Pass, Low Pass) for front and rear speakers, and Alpine amp has Gain, Bass EQ and LP Filter. could you share? thanks.
It kinda depends on the deck you have. If you have a good HU, you can control what goes where form there. For the 4 channel, you don't want to put too much of the low frequency into it since you have a sub for that. I have a RF 4 channel amp that is a step up, but it has the same features. I have it on all pass, but I control it from my HU's 16 band EQ and have the gain set on 3/4. THen you feed all your low freqs to the sub.
I have only factory head unit, it does not have eq and I use PacAudio C2A-CHY that will allow me to add aftermarket amplifier without taking out factory amp. I read somewhere and the person used High pass for front and rear also. What frequency you set for your amp?
sj2000
sj2000
Colorado
sj2000
