How to wire two Type Rs to 1 ohm? 2 ohms?
If the subs are dual 4 ohm you can wire them both to 2 ohm and run them out parallel to the amp to get a one ohm load. The only other option with these subs is wiring them to 8 ohm each and pulling a 4 ohm load from your amp. Running parallel means running the positives together and the negatives together. What amp are you going to be using? Just want to make sure it's 1 ohm stable. Most amps are 2 ohm stable. Here's a link you can use that will tell you how to wire the subs themselves.
http://diagramwiring.net/dual-voice-coil-wiring-driver-by-stereo-integrity/
What banana plugs are you referring to? Are you talking about the spring terminals for the speaker wire on the sub itself? Its got 2 positives and 2 negative right next to each other right?
The spring terminals. Ok. So are you going to wire the subs together to one speaker terminal or wire them apart to 2 separate terminals?
My amp does 1200 watts RMS at 1 ohm and on the amp there are two terminals (2 +, 2 -).
It's a 1 channel mono amp but and has output for two subs. All the wiring diagrams I've seen only has one speaker output. Even the wiring diagram that came with the amp is that way.
edit: just saw this post
If its a mono block amp and it should be. Those two terminals are really one. There are two to make wiring mulitble woofers easier.
I was not aware of that. So just use one set them wire them according to the diagram for 1 ohm?
You can't do 2 ohms with two dual 4 ohm subs. You can do 1 ohm. You need two jumpers per sub. Run one jumper from black to black and the other jumper from orange to orange. Now just wire one of the two sets of speaker terminals from each sub to your amp.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
120
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
624
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
918
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
892
skatingrocker17
skatingrocker17
Ohio
2RZ-FE
audiobaun
    May 19, 2024
    May 19, 2024
