How to wire two amps?
jeeper2269
I am running a single 12" Fi sub on my JBL. BP1200.1
and a set of boston pro series 6.5 components in the front.
I have the following amps,
kicker zx350 for the bostons
and the jbl amp running the single 12
how do I wire them off a stock deck 2006 Toyota Tacoma 4x4.
You will need what I call Hi to Low converters. They are electronic devices that convert your radio outputs to the RCA style plugs.
Any signal that is amplified is considered a "Hi" output. These devices take the Hi output signal and lowers it down to an acceptable level for your "Low" inputs on your amps.
You might wanna check out Tundrasolutions.com ...
They have a lot of info their and probably some wiring diagrams for the Tacoma's stereo system. I know on my Tundra there was a factory amp so the speaker signal comming off my head unit was actually low level already. All I had to do then was solder/splice some RCA ends on them instead of using a LOC, w/c I did by mistake.
jeeper2269
jeeper2269
Somewhere, OR
mit42ls
