How To wire Toggle Switches?
That one is pretty easy, friend. One side has 12v power coming in and the other side is for 12v power going out to whatever accessory it controls (in this case your Pioneer)
Hook up 12v power to one terminal and the output side connects to your in-dash. If it powers the in-dash when the switch is in the 'Off' position then simply switch the terminals around the other way.
this wire goes here, that wire goes there
flipy it turny, clicky it broken! //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
find the blue wire from the rear of the headunit and run a wire from it to the switch terminal on the back
connect the other terminal on the switch to the wire that was connected to the blue wire behind the deck
thus when the switch is on the amp is on, when the switch is off the amp is off
if this isin't your intent then just ban me
Record Holder07
Record Holder07
H.H.I.
Decipha
