how to wire to 2 ohm load?
brybry354
do you do it with the speaker wire or the RCA cables?
how do you get these subs:http://www.sonicelectronix.com/item_8456_Kicker+07C104.html
to put out a 2 ohm load with this amp:http://www.sonicelectronix.com/item_6750_Kicker+ZX300.1.html
using this wiring kit:http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK8
what do you do to wire the subs to a 2 ohm load?
use the RCA cables or speaker wire?
are you planning on running a pair of those subs to that amp?
Here you go.
and for future reference if you go to http://www.rockfordfosgate.com and check out the lower right hand corner you will see a link for Woofer WiringWizard
The speaker wire included in that amp kit should work fine for those subs.
yeah im powering 2 subs with the amp.
so i just split the ends of the (+) and (-) speaker wires and tie each end of the (+) or (-) to one of the subs?
typically you'd just connect two wires each to the amp's (+) and (-) speaker outputs, and run a pair to each speaker.
You could also run a (+) and (-) from the amp to one sub, and run another set from the first sub to the next.
Physically they're different, but electrically they're all the same connection.
brybry354
brybry354
Texas
brybry354
