how to wire need helpppp
rj22beast
im new and i need help wiring, i was told to run my wiring parallel for the best efficiency, i have 2 rockford frosgate 10's and a 500w momoblock rockford frosgate amp,
the subwoofer specs;10" Dual 4 ohm Shallow Mount Prime Stage 2 Series Subwoofer
Power Handling:
Peak: 400 watts per sub
RMS: 200 watts per sub
Impedance: 4 ohm
Mica injected polypropylene cone
Black raised surround
Linear spider with 16 AWG woven tinsel leads
StampCast basket with integrated spider venting
CEA-2031 Compliant accurate power handling rating
Designed for use with sealed and vented enclosures
High temperature voice coil
Integrated PVC trim ring
Anodized aluminum voice coil former
Frequency response: 45-250 Hz
Sensitivity: 82 dB
Mounting depth: 3-7/16"
Cutout diameter: 9-1/8"
the amp specs;Brand Rockford Fosgate
Model R500-1
MPN R5001
UPC 011110813565, 780687328818
Key Features
Amplifier Type Mono Channel
Channels Mono
Bridgeable Bridgeable
RMS Power at 2 Ohms 500 W x 1
RMS Power at 4 Ohms 320 W x 1
Frequency Response 20 Hz - 250 Hz
Signal to Noise Ratio 105 dB
THD at Rated RMS Power 1 %
Crossover / Equalizer
Bass Boost
Low - Pass Frequency 40 Hz - 130 Hz
Technical Features
MOSFET Circuitry Yes
3 Way Ready No
sorry for the long post and any idea for the wiring if i could get a diagram of all the system from the battery to the amp to the woofers to the radio, and thanks and if you could perfeer a 2 omh or 4 and how to wire thanks
rj22beast
rj22beast
houston
rj22beast
