How to wire a system in my house
  • Thread starter Unregistered
  • Live activity
  • Replies 4
  • Views 1K
U
Unregistered
Guest
I am trying to wire up a 12"polk audio sub with a brand new blue series pyramid 2 channel amp. 300w each or 6oow branched. How do I do it and what type of power converter do i need (how many amperes), or can I use a car battery with a charger.
600 watts at 12 volts needs 50 amps. At 60% efficiency you're talking 90 amps. That's a big-*** power supply and it'll be hard to find one that big. A car battery would go dead in 20 minutes. You need a battery and a realy big charger (the equivalent of a 100 amp alternator).
You'll also get 60 cycle or 120 cycle hum because battery chargers are unfiltered and unregulated. Car alternators are 3-phase and have very little AC ripple, battery chargers are not. The hum will drive you nuts.
Do you happen to know of any other way I can do this. I don't think I will be using all 600 watts. I think I am just going to use the 300 watts for now, because I don't know how many watts the sub is. People told me it will between 3-400 watts. If you know, please tell me. It is a 12" polk audio sub. It is a DX12 series. That is really all I know about it. Can I use one of those caps in my home to help power it. If so what kind. (New to this audio stuff)
YOu need a 13v power supply
Pyramid makes a bunch of them
They're big and hot, but if you want to be safe and still run your shit, its the only way
WIht like a 100 watt amp you can run it on a little DC converter, but it will blow before to long. But above that, you simply need to buy a power suply
Guest
B&R Innovations
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
