How To Wire A 2 Ohm Type R To Amp?
Should i run it at 2 ohms or 1 ohm and what kind of amp will do the trick?
you should try to run it a 1 ohm depending on what amp you get. amps that are 1 ohm stable or a lot cheaper than amps that do the same wattage but are 4 ohms. btw you cant run that sub at 2 ohms unless you get another one, or only power one voice coil and that could damage it.
2LouDFoRThiS
2LouDFoRThiS
TORONTO
wilzyx
