How to wire 4 sub ASAP
I made a box with 4 subs 2 normal and 2 inverted, should i conect the inverted subs inverted, and if so, could somebody make a diagram of it.
ASPA cause my client is coming tonight and i dont have that point so clear.
Well, what are the VC configurations, the resistance of the coils, and what do you want the final load to be ??
4 ohms. . . . //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
yeap. series and parallel instaltion, just want to know if changing the wires of the inverted (inverting wires to) i can make the 4 subs to move sincronize.
I'm pretty sure this is right, someone correct me if I'm wrong.
sigh...will they never research?--- in the SAME FORUM even! Yes, if they are inverted then they need to wired "out-of-phase" so the cones are all moving in the same direction... prevent cancellation
http://www.caraudio.com/forum/showthread.php?t=31984
I ask the question in that threat but nobody response, i know you have to wire the subs out of phase when they are inverted, just want to know what to do cause i have 2 inverted and 2 normal, but anyway thanks for your time
Symon_say
You can't get me
Symon_say
Dominican Republic
ultimate157
michigan born
    May 14, 2026
michigan born
    May 14, 2026
