how to wire 2 DVC subs to rockford 1000.1 amp
  • Thread starter <muff_man_aj>
  • Start date
  • Replies 2
  • Views 2K
  • 2
I'm pretty sure those subs have 4 ohm voice coils. So run everything in parallel. Run all the positive connectors to the + connector on the amp and do the same for the - connectors. That'll give you a 1 ohm load on the amp and it should handle it fine.
Alpine's can usually take a lot power and rockford amps can usually kick a lot of power and are bridgeable and stable at low impendance so bridge them like the other guy said -to- +to+ and to one speaker and parallel to the second and you'll be fine.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
387
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
873
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
993
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
996
Guest
BigAudioJoe
