How to take off tint- HELP
WD 40? Hmmm
First i started with razor blades cause i had a few layers and that got the tint itself off but then there was a thin adhesive layer still left on bottom and i sprayed it down with wd-40 then used the razor blade and it came right off with no force.
Was the window smooth after that or did it have bumps and such things?
Perfectly smooth as if it was brand new it got evreything off.
1.Razor blades to scratch off tint itself
2.After that there will be ususally a few nicks of leftover tint that need to be scrapped off too,And a thin layer of sticky adhesive
3.I sprayed wd-40 all over that and let it get kind of damp and then scraped off adhesive
4.Got some glass cleaner and sprayed down glass after that and it was as if the window was new.
slit the corner of the window and yank that ***** off, just make sure you dont crack your window, i worked at the manhiem auto auction and i cracked the window of a Benz S500. Not good. When the tints off, its just window cleaner foam to get the glue off, thats the worst part because it takes forever.
dude take a razor blade and some windex qnd your set tint my unlce scott johnson tints windows for a living
he did mine
goo gone = amazingness
there are at least 10 million usses for that stuff. its up there next to duct tape...
it should work, but why would it even matter if someone already said how they do it with step by step instructions....
Raisedin305
Banned
Raisedin305
Miami,FL
Raisedin305
