How to Seal off my Trunk????
hope that helps
I did a setup in my friends car like this and its pretty much set up like a blow-through, semi-wall.. Completely sealed off from the trunk with foam, 16gauge angle iron, and resin.. And a custom mold for the rear deck to seal that as well. Did a false floor to make everything within the same level.
if you open the trunk, does your music change at all? like do you loose bass? if so it is because you didnt seal it off from your trunk
I've seen some setups that weren't sealed well enough and they gained on the mic with the trunk open.
Korn4Life
SUB LOVE
Korn4Life
PA
TnT_Sounds
