luckymoo09
You already have iPhone or iPhone 3G or will have it, but how to make full use of it in the aspect of entertainment. Tipard DVD to iPhone Converter can convert your DVD to iPhone, iPod, Apple TV MP4 video format and MP3, M4A, AAC, WAV music for you to enjoy the portable player anywhere and any time. The following is the specific guide for you to follow:
Preparation:
Download and install Tipard DVD to iPhone Converter. After you download it, double click the file and follow the set-up instruction to install it.
Step 1: Run this DVD to iPhone Converter and load your input DVD files.
It allows you to load DVD, Load DVD Folder and Load IFO File.
Step 2: Set up the output profile and the output file path.
Tipard DVD to iPhone Converter can convert DVD into these formats:
This converter provides more video and audio parameters for you to get the perfect video quality for your player. Click “Settings” button to set it.
Click “Browse” to choose the path for you to save the converted file.
Step 3: Start conversion
After you set all the settings, you can click “Start” to start conversion.
Tips: Tipard DVD to iPhone Converter can help you to edit your video
Effect: Click “Effect” to adjust the brightness, contrast and saturation of video and volume of the audio by drag and click the adjustment bar.
Trim: Click “Trim” to capture any time-length video clips. You can set the “Start Time” and “End Time” to set the time of the clip or you can directly drag the slide bar to the accurate position.
Crop: By using the “Crop” function to crop off the black edges around video and adjust the video play region. It allows you to set the Crop Mode and Zoom Mode.
Snapshot: Click “Snapshot” button to capture your favorite picture when you preview, then click “Folder” button to open the folder where the captured images are saved.
Merge into one file: Pick the chapters or titles that you want to join, then click “Merge into one file”. After conversion, these contents will be joined into one file.
Tipard iPhone Video Converter is another useful tool for you to convert any video sources to iPhone MP4 format.
Now you can enjoy your favorite video on your iPhone!
Preparation:
