how to notice a bad ground?
Beatin'
if your amp has a bad ground, will it not put out rated power? The signal will be clipped right?
Could you tell that you have a bad ground by the amps temperature getting hotter than it's supposed to be at rated power for a duration of time?
Pretty much.
Goes into protect
More dimming than usual
Noise
Heat- Though some amps just run hot.
Popping fuses might be associated as well, though i've never had it happen.
put the meter on ohms and put the red test lead on the neg of the battery and the black test lead on the ground that you are trying to test. you want a reading less then 0.4 ohms
personally i prefer to test the continuity of the ground. not the resistance. but to each their own i suppose. and the best way to test a ground is to make it right.
Matt
Measure DC volts right at the amp power terminals with the system playing. That's the only thing that matters. The symptoms of a bad ground vary greatly and there's no guarantee you'll notice them.
my bad, i used the wrong word. continuity is in fact just if the wire is "unbroken". my uncle has a DMM(or something like a DMM) that plugs into a wall. you insert one lead in the wire before the ground and the other you bolt to the chassis ground up front. it gives you a reading, but its not in ohms.
Matt
how would you go about doing that? Putting the red test lead on the power terminal and the black lead on the ground terminal?
I thought that was dangerous......might damage the amp.
Beatin'
Beatin'
MI
maylar
