how to mod an mtx 1501d
hmm well i removed the cover from my amp and located chip and i tried getting it off with soldering iron. well i was like hmm maybe i gotta take the circuit board all the way off and do it from the backside. well i tried that and the **** soldering iron wont melt the stuff. so wat am i doing wrong?
well i can't make new topics atm for some reason.. so .. would this modde amp be good for a XXX 15? and if so, what voltage should I run it at? thanks!
A lot of people use that setup. As for what voltage to use, if you can keep a steady 14.4 on it, youll be fine.
try a high power (hotter) soddering iron and use plyers to pull the piece out as you sodder....... i had to do a repair on a memphis 1000D before and the sodder they used on the boards takes some HOT *** soddering guns......good luck man
BTW my xxx15 comes back tomarrow or the next day from it's reconing and my Fmod subsonic filter should come about the sametime too............... YESSSSS
BassAddictJ
BassAddictJ
FL
BassAddictJ
