How to make custom exhaust stacks
Dean
Bangin' S10
I have a 1991 Chevy S10 4.3L v6, and was interested in getting dual exhaust stacks. How would I go about doing so? Could I use pipe and just cut holes in the two front corners of the bed? All thoughts and replies are appreciated, thanks dean.
ya its a dumb idea; but just bend some pipe and such and run it up thru the bed... i dont suggest you do this because there will be countless people lafing at you when you pull up
you wont have enough back pressure to allow you engine to run properly. Your going to have problem when emission times come around!! Now if you did switch over to a diesel then I'd say hell yea but if you cut the engines back pressure your going to eventually blow the top or bottom end because its going to over rev!
Dean
Bangin' S10
Dean
Western MA
lovindabass
