how to lower your impedence load
saltyreefguy
I noticed there seem to be plenty people running on .05 load or lower, question for you guys, how can you get to run that low load setup, will the subs be able to bring it down that low? or do you have to use a device or module to lower the inpedence load?
I guess my topic was not phrase correctly... i was not looking to find out ' how to ', but how and why...
Why do you want to know how to lower it, all you do is add more subs or just start with a low impedence sub and wire it in parallel. everytime you add a sub it cuts in half (parallel)
hahaha, let me rephrase myself. i was reading a current thread of one person has his subs setup for .05 load, so i was wondering, what kind of subs wired will bring to those numbers, and so they can get the most power out of their amps?, if their amps will accept that low load.
also is it 5 subs with 2ohm dvc wired in series will output that number?
its not what i am trying to accomplish with my setup, i was just merely trying to get an understanding of how and why do they you run at that load. but i guess its a useless question, since nobody would ever ask that type of question, correct?..
incorrect. You just did
Its a useless question because there's too many variables, impedence of sub, dual or single voice coil, how many subs, how its wired (seres, parallel, or both)..etc.
i went to the cardomain sub wiring calculator, and it was 4 svc 2 ohm subs in series to achieve .05, so that was part of what i was looking for?
but i thought you said it was ' a useless question ', is it?
saltyreefguy
saltyreefguy
palmdale, ca
05fronty
Mike Mccabe
