How to hook up Subs?
This is what I'm working with:
This is my trunk:
This is the battery and the amp:
Amp and harness:
If you don't have any carpet or anything back there...its gonna rattle like a *****.
LOL, i took all that stuff out. Its a 2009, you really think there isnt a carpeted trunk?
Obviously im not splicing into the amp harness for power. Just a signal. I have JL Audio 4 gauge wire for that which i will hook directly to the battery. Power and ground arent the issues here. Getting a proper signal to the amp is.
Depends how in depth you want to get.
A line out converter will work. If your run a Monoblock off the LOC, wire the positives on the LOC together and the negatives on the LOC together. Then T into either the left or right side and SOLDER them in. Cover with heatshrink then run your RCA from the LOC to the amp. For remote use the ACC wire from the factory amp. Again solder and heatshrink.
Ordered a converter since its obvious i will need one no matter what route i take. 15.99 from Best Buy.
If i wire each woofers coils in series with itself, than wire the two woofers in parralell to the amp, will that give me a 4 ohm load?
michaelg589
michaelg589
Atlantic City
michaelg589
