how to hook up my friend system to make it sound the best
tolzmann_
My friend has a 1988 bronco. He has a sony exploid deck, 4gauge power wire a 1000 watt v12 2-channel amp. He has 2 15in rockford dvc subs in a sealed box. Right now the subs are put in there own channel and the amp is 1/2 way up i want to know how we can hook this system up and get the most out of the amp and the subs.
what should i do with the amp the subs are hitting good now but i know 2 15in dvc can hit harder than they are, think running them in parallel or doing anyhtin with the amp would help us out? and do you have any i dea what that amp is stable at?
with two dual 2 ohm subs you can get a .5 or 2 ohm load...now as for your box...what are the subs currently in for size wise? How much space is he willing to give up?
Thanks
Ac
I'm not positive on the dimentions of the box but it takes up the whole back area of the bronco be hind the back seat to the tail gate. The box is sealed and the subs are sealed off from each other. there in different chambers in the box
91
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
tolzmann_
tolzmann_
Waterville, MN
tolzmann_
    May 31, 2024
    May 24, 2024
