how to fiberglass inclosure
do you know about how much the total will be to fiberglass a 1 cubic foot box?
Roughtly
~30$ for a gallon of Resin
~20$ for the fiberglass cloth
~06$ for blue masking tape
~12$ for brushes, mixing containers, acetone
PLUS, add in cost of any mdf used, body filler and masking meterials such as sheets of plastic to mask off parts of the car and a resperater for breathing. Its also good to have a set of high power work lights (two high powered lights on a tripod.) They give off alot of heat, which is good when you want to have the resin dry faster.
You can spend from 60 to 100$. If you start adding in paint, etc....
As far as time goes....
building an wood box from start to finish might take a night or two.
fiber glassing takes MUCH longer, but if you do it right the end result is well worth it. Say from 12 to 20 hours. And if you want the end result all smooth and painted you can plan on added on another 5 to 15 hours.
True , and you can use a heat gun or hair dryer to speed curing for a lot less than lights would cost //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i want to fiberglass a inclosure for my 2 10's, how hard and how big of a task is it to get into?
I think you should know how to spell "inclosure" before you can build it.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
500000watts
500000watts
MI
disturbedfuel15
