My last words, it is perfectly fine to make all your calculations according to how much current your amplifier can draw. This is the easiest way to make sure your wiring will be more then adequate. The only problem with doing it this way, is that the amplifier no matter what, cannot draw more current then can be provided through the power sources (ie alternator and batteries), which is where my calculations come into play. The day I have a problem with any of my wiring, or any of my friends, family, acquantances who I have helped in the past have an issue, I will stop using circuit theory, and go back the the simple form of guestimating (which as I stated above is perfectly fine, if you are uncfomfortable using math.
Edit: Also, since I will admit when I am wrong, one always needs to either calculate or look at a chart to see if your calculated number for current draw will fall into the the safety zone with regards to thermal capabilities of a specific wire. I appreciate everyones input on this thread (my original post was asking for feedback and suggestions which also got removed because post took up 1/2 a page), and next time before I just throw out a post in 5 minutes, I will make sure I cover all of the topics relevant. Sorry for the hastle guys, I will admit that I have probably lucked out in the past using such calculations, but I always error on the side of caution so maybe thats why I got lucky. You best believe that mistake will not be made again. I am going to continue to do these calculations, and ones like them because I personally find it very interesting how close your actual results are compared to what you predicted.
