How to calculate volume in a box like this...
Originally posted by Afboy143 How do i calculate volume that looks like this
___
|_____\
Because Im building a box for my s10 truck and i need to find out how to find the volume
Thanks
Curtis
Basically, you draw a line down from the shortest part straight to the base.. that gives you a rectangle (easy enough to calc volume there).. Then, you have a triangle left.. the formula for the volume is (I believe) 1/2 x base x height x width.. basically, it's 1/2 of the comprable rectangle you would if you took 2 triangles and flipped one over and put them together to make the rectangle.. make sense?
.___
|.__|__\
Hope that helps..
ya take the top measurement and the bottom add them say 8 and 12 that be 20 divide by 2 so you get 10 then muliply that by height and width. after gettin that number divide by 1728 to get the volume in cubic feet
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
79
381
Factory. 2021 Chevy Silverado custom trailboss
530
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
857
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Afboy143
aka Bumpin Expo
Afboy143
Tampa, Fl
geonn
    May 12, 2024
Brendon Jenness
    May 11, 2024
