Basically, you draw a line down from the shortest part straight to the base.. that gives you a rectangle (easy enough to calc volume there).. Then, you have a triangle left.. the formula for the volume is (I believe) 1/2 x base x height x width.. basically, it's 1/2 of the comprable rectangle you would if you took 2 triangles and flipped one over and put them together to make the rectangle.. make sense?
ya take the top measurement and the bottom add them say 8 and 12 that be 20 divide by 2 so you get 10 then muliply that by height and width. after gettin that number divide by 1728 to get the volume in cubic feet
