How this looks for a Single Sa-8
Looks like you didn't input the subwoofer displacement, which I believe is 0.1ft^3 for the SA-8. You will need to change the design to account for that.
You also need more port area. 12-16 square inches per cubic foot, so a 1" wide port may serve you better if you have the room for the needed slot port length.
I bet that dude didnt even look at the design, just wrote a random generic post that he felt would fit, so he could raise his post count.
Yea either that or he knows nothing about desiging a ported enclosure and should refrain from giving advice.
My bad I realize I need around 10 to 12 square inches of port area
This is gonna be my first ported box I wanna tune it low, Its going on my girls car and also I dont wanna use the whole trunk
When in doubt, use an app called Signal Generator and play tones in the tens. The phase will be easier to distinguish.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
531
821
jeyventura
Pumping UP
jeyventura
Port Charlotte Fl.
supermaxx123
SPLBassJunkie
    May 21, 2024
    May 20, 2024
