How much power is given?
gumby688
Ok so lets says you have 4 d2 speakers and you run them in a series/parallel set up to make a 1 ohm load off a 1000 watt @1ohm amplifier how much power does each see in this set up?
Row 1 = 2 voicecolis in series : 2.00 ohms : 2.00 ohms
( 4.00 ohms total for row)
Row 2 = 2 voicecolis in series : 2.00 ohms : 2.00 ohms
Row 3 = 2 voicecolis in series : 2.00 ohms : 2.00 ohms
Row 4 = 2 voicecolis in series : 2.00 ohms : 2.00 ohms
Connecting Row 1 and Row 2 and Row 3 and Row 4 in Parallel
Total Impedance for this combination = 1.00 ohms
so if you had 10 speakers same set up same amp each would see 100 watts then ok I am asking because I am going to be setting up a wall with 8 12's in my explorer and would like to see about 500 to each sub so that means I would need about a 4k watt amplifier then right?I want to run just a single sub amp though
If you want a full 500w to go to each sub, I would be looking at something that does what you want at 2 ohm. Your box rise will put you closer to that rating or higher.
So you want 4-5k at 2 ohm.
gumby688
gumby688
Fryeburg,ME
gumby688
