How much does box size matter?
cyber256
I have a duel 12" box (3/4" MDF) with 1 cubic foot on each side. I got this box because I got a deal on it and was short on cash after getting my subs and amp. I have 2 12" Eclipse 88120 DVC (500wrms) being pushed by a JBL bp1200.1. I've got everything wired correctly presenting the amp with a 1ohm load (it is 1ohm stable) but its not as deep as it should be. How much bigger should I make my box in order to correct this? I have not seen many Eclipse setups but I'm sure someone here has //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Thanks for your help
If the box is built well, then you shouldn't need more than about 1 cu ft internal because those subs like small sealed enclosures. You might get a little louder sound if you increase to about 1.25 cu ft int, but you'd probly lose a little bit of the punch of the bass. Go look on eclipse and see what they recommend for their speakers and go from there
cyber256
cyber256
Frozen Tundra
cyber256
michigan born
    May 14, 2026
michigan born
    May 14, 2026
