How much can one run take?
how abouts an autotek4000.1 (4krms) and two 100RMS 2ch amps? can two runs (one pos, one neg) handle that? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
1/0 can handle 300-350 amps without endangering the wire. But the resistance may be too high and your voltage drop (and amperage go up) from front to rear while under full tilt too much. Running a second run will lower this resistance and you'll have less of a voltage drop. Most likely 1 run will do it. Only way to find out is try.
muskyhunter567
Truck Do Burn Rubber
muskyhunter567
Milwaukee Wisconin
jrwalte
