How much can a Fi Q take daily?
i had 3000 watts on my pair and they took it, never bottomed out, but after beating on them a while you could smell coil. if you want more power handling, spend a few extra bucks on a bl.
The q's have a significantly softer suspension than bl's and btl's.
Mines getting around 1500rms. My cars electrical can't take me turning the amp up any higher.
Haven't smelled it yet, but considering i got it from gta he probably burned off everything already.
That and i don't have any sound deadening in my car other than the trunk lid so the panel vibrations get STUPID when i crank it, so i don't do that for extended periods.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif yep.
I think i should have tuned the box a little higher, or it needs bracing. Probably both. Although i did do a 1 inch void free birch front plate. It's 4 cubes at 29hz. It kinda gets sloppy on double bass not bad but i notice it. Hell it could be car panel vibrations making it sound sloppy.
I'm gonna build a new box once it gets a little above freezing outside:uhoh:
But yea, that sub wangs. Gonna see if i can get it metered, i found a guy with a tl thats within 20 min of me.
For the o.p. the q is better if you want to get loud on less power and get more sq. The bl is a little less sq and a little more spl, increasingly so with the options which can increase the power handling quite a bit. The bl's have potential to get louder than q's, but probably won't be much.
http://www.realmofexcursion.com/videos/FiCarAudio/q15.3.wmv Theres a vid of mine if you wanna check it out.
i checked my gains today with my dmm and i had them set to 2200.... and i never smelled it nor did it show any signs of having a problem with it. I'm not condoning running that much as i backed my gains down to 1800. Just telling you, they're beasts.
But there also being run in an area thats never above 50 degrees in the winter.
Got my 12'' in a sealed 1.66 after dis. on a Ma 401sx which produces 1200rms at 1ohm with only a little over a quarter gain. sucker moves like crazy. Im thinking the Q is pulling more than 1200 since it dual 1.7 if I recal will will actually pulling watts at around .7 ohms on the amp and my 401sx rates 1800 at .5 sounds and wangs good thought. So I would recommend around 1300 of cleean watts depending on box size.
Pickler
Pickler
Las Vegas
profundus-sanus
Mike Mccabe
