osixfrontier
okay im getting ready to add my second z1 to my system...they will be strapped at 1.4 so each amp will see .7 BUT i have a rise of a little over 1ohm...weve checked....
im gonna run this daily and by daily i mean every single day as its in my beater car i use to go to work..
i have a ho'er alt on order from ho alternaters..its a 200 amp model that should idle 100 amps...i eventually plan 2 alts but that is in december sometime.....i have a volt meter and all so i can constantly moniter voltage...
i already have a kenitik 1400 (under the hood) a g31 optima and 2 2400's....only 1 2400 is installed the other is on the side gonna install when i install the amp..
i also charge my batts via the kinetik charger over nite every other week or so.
my question is is that enuff as far as batery goes so that i could full tilt a song or 2 for demo purposes car on of course...or should i get more battery (space is perty limited)....
as it is now with just th 1400 2400 and g31 with 1 z1 and my slightly upgraded alt (90 as compared to stock honda 60) i stay at 12.8 or so at full blast.......
i could do 1 more g31 or 2400 but i really dont want to if i dont need too....plus the weight is tad much for an 20 year old suspension....
