how much 1/0
well i do not know exactly how much u will need but ill tell you to take what ever u think u need and add a couple more ft to each side. nothing like running ur wire to the trunk then realizing your 2 or 3 feet short. or run out while doing the big three so u only have 2 of the three done.
That's a pretty circumstancial question. Unless someone on here has nearly the exact same car as you no one is gonna know. It also depends on how you plan on running the wire through the car. Best bet is to just break out a tape measure.
if your doing a run of pos and neg you do the big 2. alt to batt. alt ground to batt. no need to touch the frame. if the battery isnt very far from the alt you should be fine with 30 feet
tacovic
tacovic
twin cities
tacovic
