How low can you go with the Iridium 8.3i?
oh yeah... i forgot to mention that its not for active setup, but passive... anyway... should i change my amp to a bigger amp, most probably dls a3, will i need to change my xover setting?
Its probably going to be volume dependent. They will probably be fine at the lower setting as long as the volume is moderate or lower. If you start turning up the volume the setting will need to be raised as well.
scarysoul
scarysoul
Brunei
adam71
