How is this possible?
i2ain2thunder
These are specs I found for this MMATS amp below.
M1400.1D/M1400.2D
M1400.1 M1400.2
STABLE TO: 1 ohm 2 ohm
CONTINUOUS (RMS) POWER
@ 13.8 Volts:
Watts @ 1 ohms mono 1 X 1400 N/A
Watts @ 2 ohms mono 1 X 750 1 X 1400
Idle Current: 1.5 amp 1.5 amp
Signal to Noise Ratio A-Wtd:
Total Harmonic Distortion: 0.3% 0.3%
Channel Separation: N/A N/A
Input Sensitivity: 150mV-2.5V 150mV-2.5V
Slew Rate: 13V / Usec 13V / Usec
Fuse Rating: 80 amp 80 amp
Dimensions:
Height: 2.25” 2.25”
Width: 9.5” 9.5”
Length: 8” 8”
General Information:
Frequency Response:
Low-pass Filter: Variable 24db, 77 to 275Hz
Battery Connectors: 2 Gauge
Speaker Connectors: 8 Gauge
Now I understand MMATS are very good amps, US Made underrated, blah blah.
As far as I understand basic electric Volts x Amps = Watts...so this amp uses 80 amps for fuse rating. Constant voltage to the amp will prob be around 12-14 volts. no this gives us a maximum watts of between 960 and 1120 Watts,
Soooooooooooo
How come it is rated for 1400 Watts RMS?
i2ain2thunder
i2ain2thunder
st paul, mn
GVP
