How is this AMP?
tK715
JL 500/5
for... 2 12" infiniti references (each 300W, 4 ohm), and mb quart components.
will the 500/5 be okay for this setup? thanks in advance. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You need to give us the exact models of your equipment to be certain but I have some info for the amp. JL amps can't be wired to any ohm they are just more... flexible. The front channels would be at 4-ohm stereo with 100w RMS into each side. With those subs you could wire them to 2-ohm getting 250w RMS total to the subs. That's a little weak for those subs, they could take more... I am assuming the 300w each you said was an RMS rating, once again I just can't say for sure...
tK715
tK715
la la land
cjjackson85
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
