How is this amp a monoblock??
it is bridged internally, they are just one channel, but it gives you the ease of hooking it up with 4 terminals instead of 2, for possibly multiple sub setups or multiple vc's and what not
That's awesome.
I want one of those //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so what would be this best way to wire 4 svc subs (either 2 or 4 ohms) to one of these amps...and what load would the amp see them at
so your saying you have 4 single voice coil subs? what ohmage are they? need that to figure out the load. also the best way to wire is is determined by what stablilty the amp is.
nvmd...i looked it up on rockfordfosgate wiring wizard....i don't have the subs yet, just figuring out what ohmage i should get them in and what load i want the amp to see them at....i think i'll go with 4, 4ohm svc subs to wire them all at 1ohm....to a 1ohm stable amp
most mono amps have this nowadays.
Its just 2 sets of terminals that are connected in parallel.
You can do 4) 4ohm SVC subs, all connected in parallel to a 1ohm stable mono amp.
302yota
302yota
rockingham, NC
Ed Lester
NorthFramingham
    Jun 30, 2026
