re-resined layer in between the dual 3/4" MDF baffles to make a secured seal on the front of the enclosure.
Here i poured in more resin on the back side of the port roll form and set it at an angle to solidify, and as you can see i added the top plate baffle
After some sanding, re-resining, and sanding again I got the form smooth and painted over it.....and finished it with some Krylon //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Then pulled off the tape to reveal the georgous marble below.
this is the 45 deg bevel on the inside of the box behind the sub
Here you can see ive added the port side baffle and buttoned up the end of the enclosure, and getting ready to drop in my 4hp
and here it is in the first test session of the box in the jeep....a little rough looking even still, but pretty boxes arent loud //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And as you can see above, at the Db drag finals it still wasnt in a pretty form, having no carpeting or paint. I might duraline it still, Im unsure. Maybe just a nice paint job on it will do. Anyways I hope this spawns some ideas for you folks out there to get out and work on your ride's setup.
