How good will this bump 06 S15L7's?
Thank you very much for the diagram, that is how they are currently wired. There is ONE piece of speaker wire running from my box, a positive and a negative. Thus running the two paralell if I'm correct.
I take this one piece of speaker wire, the positive and negative, and hook it into the only two terminals on the amplifier, the positive and negative, and it should run both speakers at 1000 watts rms.
The lanzar was a viberant 2000 watt two channel amplifier. It was refurbished (my first mistake in buying it) I hooked my speakers up the way they are now, paralell at 2 ohms. Ran it into the bridged ports, fired up my car and the two 25a fuses blew out. Tried it again and they blew again. Protection light has been on ever sense, am gonna use the warranty to get a new one and just sell it to someone for 100 bucks or so.
I have just bought a new amp after returning the old lanzar piece of trash.
It is a Phoenix Gold R15.0 class D mono amplifier. What is strange is that is has 1000 watts rms at 2 ohms. Not 1 ohm stable, and it is not bridgeable.
How would I hook my dual (2 ohm..that's 4 ohms total per subwoofer) voice coiled L7 15" 06 kickers so that it runs at optimum level without me dropping the ohms too low or not getting enough power. That was my second question.
If I read this right, wiring just one sub is going to drop the load to one ohm. maybe you can wire the subs to a higher ohmage, but you wont get near 1000 watts RMS. You need another amp, or you need to get some other speakers with the right ohmage!!
we've already came to the conclusion......................
But, another question unanswered. Is this phoenix gold a reliable brand. I just need pure experience help here, to the best of your knowledge, does it put out the power it promises, and is it reliable?
All asked a little too late, but my point is I spent quite a bit of money, not a ton, but enough that I should get what I paid for you know what I mean. I can always use the return warranty.
lanzar puts out i believe 2200 X1 @ 1ohmsoundstream is over rated by like 70-100 watts. making the difference about 300 watts
or atleast thats my understanding?
who told u that OPTI puts out 2200? i heard they did rated power, but never underrated..... i also heard soundstream was overrated by alot.....2-300watts
FrozenBritches
FrozenBritches
Urich, Missouri.
ultimate157
