Depends. I've seen plenty of subs that reach their mechanical limits well before their thermal limit. Depending on the tuning of the box and the singnal fed to the sub, you can easily overstroke it with very little power. A lot depends on the actual build of the sub as well. Usually unless you are playing below tuning, the cone moves very little in a ported or 6th order enclosure. The motor of the sub is mostly just presurizing the air in the enclosure and the inertia of the air going in and out of the port adds additional damping to the cone. Send too much power to the sub and the forces exerted by the enclosure and the motor can literally tear the sub apart. This is with the cone barely moving. A 6th order enclosure exerts even more pressure on the cone...So 600wrms subs in a BP cant handle 600wrms?
Don't mind him, he pops in to threads, replys with something totally non constructive and then departs.Why it that //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Ever seen the response curve of an SPL enclosure? Just one huge peak. Guess what, horrible peaks do equal loud. May sound like utter trash, but it IS loud. The two are different things.apparently horrible peaks in the frequency response = loud now?
oh well, whatever floats your boat....
horrible peaks at one frequency vs a fairly flat response...
hmm
