How does the guts of the AP1500d look?
marvinwillis
How does this look compared to other 1.5K watt amps
I think it looks average. Some say the quality of the Chinese components are not as good as the Korean stuff. I just bought one of these for a Friend we are putting it on a dual 2 Type r 15 in a 4.5ft box 8in flared port. Finishing it up tomorrow. Ill let you guys know how it does on a kia sephia electrical. Might need an extra battery. Will be doing the big 3.
Well. I have used these amps and I must say they are kinda dirty... BUT actually aren't overrated... Actually do more than rated. If I remember correctly I tested mine at 930rms at 2.1 ohms at 11 volts after imp rise... It is rated at 950 rms at 2 ohms if I remember correctly ..... at that was at 11 volts it did it
Although his grammar was lacking... At least he is trying to research and learn... A big change compared to 95 percent of the idiots out there not on this forum... And a the 75 percent of the idiots on here that refuse to ask and just assume they are correct lol
Just installed one tonight on a Type-r 15 dual 2 ohm. Its a good amp. Good thick terminals that wont strip out, All phillips screws. Variable bass boost 30 to 100 or so I just set it 3db at 30. subsonic variable.
marvinwillis
marvinwillis
Hinesville GA
amartin_72
