How does the crossover in a component system turn two 4 ohm speakers intoone4ohm load
deeweld99
Just want to know how it works. I was confused when I was looking at component speakers when I noticed that the woofer was four ohms and the tweeter was four ohms, but when hooked up to the crossover and then to the amp that the final load was a four ohm load. How does that work?? I know that with subs it would have come out to a two ohm or 8 ohm depending on wiring, but how does this scenario make the final load 4 ohms? And if you can do that with regular speakers, can you do it with sub woofers. Like lets say you have two dual 4 ohm subs. I know you can wire them together for either 4 ohm or 1 ohm final impedance. So if you knew how the crossover in a component system worked could you then possibly wire two dual four ohm subs to be a 2 ohm load??
Its my understanding that its 4ohm at different bandwidths.
i.e. rather than a single driver seeing a full range at 4ohms, the cross over will split the bandwidth between two different drivers.
Driver one: 100hz - 3000hz
Driver two: 3000hz - 20,000hz
don't take my word for it though, i'm not certain,
thats just my understanding of it...
I believe the crossover is changing the impedance.
Try disconnecting the crossover from the speakers and put your multimeter on the input leads with it set to Ohms.
I could also be way off though. But I do know crossovers are specific to the impedance of the speakers. (Ie, a 8ohm crossover won't work properly with 4 ohm speakers)
Maybe one of the electrical gurus can chime in here? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's the way I've always understood it
... and Scoob is right about not mixing ohms. If it's made for 4 and you put 2 ohms on it, the crossover point will change dramatically.
deeweld99
deeweld99
Edinburg, TX
Gebrochen
