How does a clamshell work?
Ah, I am thinking of something else here. I was thinking isobaric enclosures using two drivers facing each other in a push pull configuration. My bad.
You were thinking correctly. The term "clamshell" was used long ago to describe an isobaric setup.
Lets say basic sealed clamshell.... Say it has a 4th order aspect to it. what would the tuning be in theory... I know it depends on the size but lets talk about something like tommy mckinny's
i tried one. Now moving onto something else.
This would be a ported box
and I may be using the term clamshell out of context . But basically subs facing each other. More so than anything 4 sides firing into each other
All hail the guy with 20 something different amps and speaker!!!
j/k...
and //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Clamshells can offer an increased gain due to increased loading on the drivers and transmission line/horn effects. The drivers in a clamshell pressure load each other and the line which can allow for greater mechanical power handling and increased output.
Don't think of clamshells acting like a bandpass because that really isn't the case unless you mass load the end of it with a port. Clamshells will are more closely related to 1/4 wave theory enclosures than to bandpass theory. In 1/4 wave theory, you have a high pressure zone that turns into a high velocity zone. The high pressure zone is the far back of the clamshell and the high velocity zone in the mouth or opening of the clamshell. This pressure transfer can cause 1/4 wave resonances that will be based on the length and geometry of the clamshell. Long clamshells will have lower resonances (like bass tunnels and Tommy's truck) while shorter clamshells have higher frequency resonances.
Interesting. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've thought about a very small diamond of 4 15's sealed in the extended cab of my truck. No idea how it would act, but would be interesting to try. Not sure if there would be enough cone area to make any thing different happen, but the volume and opening of the diamond would be smaller than any of the others mentioned.
But a diamond definately does act like a bandpass and you are totally wrong to think it doesn't.
The depth of the baffle along with the way the woofers load is what gives the tuning
vehementSPL
vehementSPL
indianapolis
TSGP
