Ideally your ground resistance should be low enough that taking a direct reading of the resistance is going to be beyond the capability of your average DMM. The definition of "ground' is a point of zero potential. With the car off, the closest you will get to this is the negative post of the battery. With the car on, the case of the alt is your true ground. Since the connection between the alt and the negative battery post should have been upgraded, you can just about count those two as the same. From the negative battery post, anything you add betwen the amp and that point is going to add resistance. You can mess around with your ground in the trunk and gamble with the true unknown of the resistance of the car's structure. Since 90%+ of the cars on the road don't have a frame anymore, your conducting path is goint to have to go through a bunch of tack welds, glued seams and bolted panels to get to the battery. the other route is to run a piece of wire the same size as your power cable directly back to the battery. You now have a known value for ground. If your power wire is properly sized, then you also know that your ground is sufficient. Of course with a system using only 4ga or smaller power cable, the chassis will work just fine 99% of the time, but once you get bigger than that, you can either guess that it will be OK or know that it will.
