How do you ground a HU?
'93 Dodge Dynasty...When I first hooked up the HU and new speakers, it worked fine for a few weeks. The other day when I was driving, I turned it off to answer my phone. When I turned it back on, only the left-side speakers were working. This only happens when I use the CD player, though. When I use the stereo, all of the speakers work fine.
SOME music does come out of the right-side speakers when the CD player's on, but it's very low.
Hmm thats an odd one. I honestly dont think a bad ground would be the issue. Nor do i think you have an issue with the speakers cause they would do the same no matter what was playing. It may be a defective headunit. What kind of head are you using?
It's an Insignia HU from BestBuy. If it was a bad head unit, would it have worked for the first few weeks? I don't know much about it.
I toyed with the idea that it might be the read laser alignment, but I'm not sure how to double check on that.
Well unfortunately thats the prob. with electronics. they can be abd right outta the box, last ten years, or only a couple of weeks. but if it is something like the laser(which would not cause your prob) or anything else internal there really isnt much you can do. have you tried resetting the unit?
Thanks, NHustla...checking into it now.
Nope...I don't know much about it, like I said. How do I reset it? And thanks for your help, by the way. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes that should be his ground.
But i have never used one of those radios so i'm not sure where the reset is on it. but if your pulling it to check the ground just unplug it for a few mins. that should work to reset it as well
Nevermind. I just called the technical support line, and they agreed to swap out the product for me. Of course, they said they've never had a problem with the product before...go figure. -_-
Thanks for your help, guys.
PeaceOfficer
PeaceOfficer
Ruskin, FL
PeaceOfficer
